"Network is unreachable" error when trying to read files
bel52
I am getting this error on some but not all of the folders within the larger folder I would like to mirror sync.
This is popping up when I am comparing files in the two folders. I can hit "retry" but there are so many folders generating the error it is impossible to hit "retry" for all of them.
Here is the error:
Cannot read directory "path to local folder"
ENETUNREACH: Network is unreachable [readdir]
The local folder I am syncing from is a Box drive folder.
therube
Box drive folder
So the files are actually stored "in the cloud" ?
"ENETUNREACH" seems to be a network issue.
So something between you & the cloud (including an internet issue).
Maybe FFS needs something like, Nodemailer - How to handle enetunreach error?
It sounds similar to a OneDrive issue where the files aren't all stored locally, so it can't sync them. Is there a way to make Box always keep the files stored locally as well?
