SMB support
Plan to support embedded SMB?
At least in the FFS Windows version, SMB seems to be the default protocol.
You can simply type
\\192.168.1.50\test (Windows notation using backslashes)
in the drag&drop field and FFS will access the network resource using the SMB protocol.
You can simply type
@Plerry useful information, thanks
It is a pity that the login and password must be saved in windows but not in the program FFS
I guess the author did not want to design a function that Microsoft had already designed for him, thereby avoiding the risk of being held liable (or the like) for any loopholes in password management ...
