Running FreeFileSync as super user (root)
spflanze
Before I migrate from Ubuntu 20.04 to Pop!_OS 21.04 I seek to do the due diligence of backing up everything in my home directory. When I run normally I find FreeFileSync cannot access many, or all, of any directory that begins with a "." because FreeFileSync did not have sufficient permissions. So I ran it as super user using this command:
sudo -i -g me /usr/bin/flatpak run --branch=stable --arch=x86_64 --command=FreeFileSync --file-forwarding org.freefilesync.FreeFileSync @@ %F @@
Now I get in the terminal emulator these errors when FreeFileSync starts up:
(/usr/bin/flatpak run:6396): dconf-CRITICAL **: 10:31:18.234: unable to create file '/home/me/.cache/dconf/user': Permission denied.  dconf will not work properly.
F: Can't get document portal mount path
In spite of these errors FreeFileSync does start up. Can these dconf errors be safely ignored? If not, what can be done about them?
therube
Seems you can safely ignore those messages.
Ubuntu – How to access and backup ~/.gvfs and ~/.cache/dconf.
