Unsupported File Types & Invalid Characters
spflanze
My OS is Ubuntu 20.04.
The below errors happened after a directory sync operation. I had already backed all my files in my /home/me directory onto a blank USB drive using the command:
cp -r /home/me/*  /media/me/AADE755ADE75202D/home/me/
This took 36 hours. Now I need to back up again. I want to copy over only what has changed, and so I am using FreeFileSync to do so. FreeFileSync output many file sync errors. Pasted below is a sample of them:
10:06:10    Error    Cannot open file "/home/me/snap/anbox/common/runtime/anbox/sockets/qemu_pipe".
        Unsupported item type. [socket, 0140000]
10:06:20    Error    Cannot open file "/home/me/.cxoffice/logs/install_LabVIEW2021_Unlisted_application_7.cxlog.fifo".
        Unsupported item type. [FIFO, named pipe, 0010000]
10:09:29    Error    Cannot write file "/media/me/AADE755ADE75202D/home/me/.firestorm_x64 2020-01-09/logs/dump-1e2b6572-��]�~763f.ffs_tmp".
        EILSEQ: Invalid or incomplete multibyte or wide character [open]
It appears there are file types the cp command did copy, that FreeFileSync cannot. Why cannot FreFileSync do the same as cp? What can be done about these errors?
bgstack15
This is a Linux-specific problem. Sockets and named pipes are special filetypes; they are used by the computer at run-time; they are not standard files that you would expect to store contents in for next time. A socket is used as a communication point between multiple processes, and the same for a named pipe. It is not a problem that FreeFileSync does not copy these files. These files will not be useful if copied elsewhere.
The dump file that you refer to is probably a large binary file (dump file being a file that stores a memory dump from a program that has crashed) that is useful when debugging a program or giving to a support team who will debug the program. I don't know much about that type of error message, but you probably don't actually need this file in the new location either.
