Virus in FreeFileSync_v4.0_setup.exe
milaa
Some anti-virus (AntiVir and eSafe) are detecting Adware/Trojan in
FreeFileSync_v4.0_setup.exe (see virustotal.com).
Is it a false positive? Could you comment, please.
Thanks in advance.
Sigh, same procedure as "every few releases". Avira should finally start to
come up with some actually *working* heuristics.
Here's the reason:
http://www.codeproject.com/KB/bugs/TheCaseOfEvilWinMain.aspx
FFS's starter uses a one-line WinMain + static linkage. Without static linkage
everything seems fine.
Some AV vendors should start cleaning their mess up!
