Unlocking performance feature
renangv
I just installed the donation version, but the performance feature is still locked. What should I do?
Thanks,
Renan
If you go to help->about you will see what version is installed. If it doesn't say "Donation Edition" then you aren't using it. I would uninstall FFS first and install the donation edition again. You got your download from your link the was emailed to you?
renangv
I had previously installed the Donation version over the Free version, but the Free one was never removed. Since I am on a Mac, I did rm -rf /Applications/FreeFileSync.app, and then re-installed the Donation version which I downloaded using the link I received via email. It works now!
Thanks,
Renan
