The realtime sync seems to give example for Windows and not for Mac.
Should the command line just point to batch file or the Application first and then the Batch file.
The automatic command line filler does not work for Mac.
Any guidance will be appreciated
RealTime Sync Command Line in Mac
Is Realtime only works for windows, the example only mention FreeFilesync.exe?
The Mac so far does not work
