error symbol and usb key
AlexFofo
Is there a way to turn off the sync error symbol for the trash problem with usb key ...
Indeed it always appears during a synchronization on this media as this one does not have "trash".
I find that annoying because although the synchronizations are correct, you get used to seeing this symbol and suddenly it greatly reduces its usefulness for the day when it will be there for another reason ...
Thank you
Change the settings so deletions are 'permanent' instead of to the recycle bin
AlexFofo
merci :-)
