[Solved] Exclude sub folders with space in the name
dav999
Hi everybody,
I have some subfolders name with space in them, and it appear that it's not taken in consideration if i place a rule like this :
\Project Alpha\
in the "exclude" textbox in the filter parameters.
I know that i can change my folder name to make it easy, but i'm sure this is already taken in consideration :)
Thanks in advance.
David
It should take that. Run a compare scan and right-click the folder you want to exclude, the exclude from that pop-up menu. See what the difference is in how you entered the filter versus the way FFS does it
dav999
Well, I have had a subfolder before the one I mentionned that's why it was not working.
the good filter is:
\E&E\Project Alpha\
Now it's ok.
Thanks for the tip & trick.
David
Ah, that will do it! nice
