Folder where FeeFlile Sybic files are saved
cbjmza
I want to change the files that FreeFilesync generates to a folder created by me, but when I go to Tool - Options- and I want to change the path; it is impossible to delete or rewrite the new address.
Please, could you tell me how to do it. Thank you very much
If you mean the logs, you can't change it.
cbjmza
Good da y. thanks for answering. No, I don't want to change the records, but rather create a folder, where the records generated by FreeFileFolder are stored. entering Tools> Options it is impossible to change the path to another folder.
Ok, you aren't making any sense.
You can't change where logs are saved
therube
The change you'll want to make is not in Tools | Options, but rather, viewtopic.php?t=7579#p25671.
