I have tried to use FFS on fedora 34. I cannot access to phone folders through FFS using native mtp protocol.
I have then installed simple-mtpfs and I can successfully get to mount the phone internal memory and sd card to a local folder which I can normally browse.
The problem is that when I look for that local folder through FFS I cannot see any directory inside.
Weird.
Any hint?
MTP transfer on fedora linux
