I have thousands of files of a certain extension spread across dozens of folders.
I keep a USB drive of just the files without the folders.
I have the donation version of FreeFileSync.
Can FFS ignore the folder structure on the left side and sync the files of a certain extension to the right side that does not have a folder structure?
If so, how?
Thanks in advance.
how to sync by extension
Not easy to use FFS without keeping the folder structure. It's been mentioned on here a few times where you can do a one-time transfer. If you are on Windows, I would use robocopy with whatever options whether you want to mirror or update the destination, and then the end can just be *.exe or *.PDF, whatever extension you want.
Thanks xCSxXenon ... but if I use mirror option, then won't robocopy just duplicate the folder environment?
Yeah, you would then have to run another command that pulls the files from their folders in the destination, not exactly the worst to do that either.
You may look into the for command line utility
If so, how?
Thanks in advance. FreeFileSyncer, 11 Oct 2021, 18:00
FreeFileSyncer
How can i contact you outside of this forum?
tell me your discord or something
Discord is xivixx
Discord is xivixx FreeFileSyncer, 14 Oct 2021, 15:27
discord is in this pattern plz check
Himusaki Maguro#5677
xivixx#9214
