Auto load on bootup
dannys22
Small problem, I dragged the RealTime Sync from the directory C:\programs to the startup folder C:\Users\Danny\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
but when I either reboot or on startup, the icon comes up on the desktop and I have to click start for it to run and go minimize. In Task Manager it shows under the startup tab and as enabled.
Thanks for the help.
Danny
Put that exe back where it was. You need to open it and set up the config, then save your config as a .ffs_real file. Put that file in the startup
dannys22
I'm sorry for being late in responding to this. I finally figured it out.
Thank you for the help.
