Running MacOS BigSur 11.6
When clicking on "browse" to select files the software freezes and I have to force quit.
Is this a compatibility issue? Is there a work around?
Thanks James
FFS freezing when selecting files - Mac
What changed since it last worked? Try an older version of FFS? Update Mac OS recently?
What if you drag & drop a location from Finder into the FFS window?
Thanks for the response; latest Mac update installed and latest version of FFS. I don't keep the packages historically but did have the problem with the older version too.What changed since it last worked? Try an older version of FFS? Update Mac OS recently? xCSxXenon, 21 Oct 2021, 14:05
I may reinstall to see if that helps.
Thanks again James
