File Sync while using Remote PC
wellhousen
Hello - Is it possible to setup a file/folder sync while using Remote PC (a remote PC connection application)? In other words, I would like to sync files/folders from the local PC to the remote PC
I guess it depends on how the remote connected PC manifests itself via "Remote PC".
If it is e.g. via a UNC or as a drive mapped to a drive letter, it should be no problem for FFS.
Basically, if you can't get to it from File Explorer, you can't sync with it.
