Error reading from synchronisation database
alienglow
I have the latest version 3.19 installed. I am using the portable version on
Windows 7 64Bit Home Basic and sycing to an external USB HDD.
I have tried deleting sync.ffs_db and run the sync. The files gets created but
next time I run a sync I get the same error.
I can send you the sync.ffs_db if required.
Thanks,
Alienglow.
The problem is most likely cause by using different versions of FFS at the
same time. Please make sure to use v3.19 consistently on all PCs. If you can
exclude this cause, please give me a detailed description how this issue can
be reproduced and send me the .ffs_db file.
-Zenju
alienglow
Thanks for the prompt reply Zenju.
I am using the same version on all PCs. Infact as I said if I delete all
.ffs_db files. Then I run a fresh sync. The file gets created. Then I close
FFS and start again and run compare and I get the error that it can't read the
DB. I can send you the DB file, where/how do I send it?
Regards,
Alienglow
Just send them to my email address (see FFS about dialog).
alienglow
I have sent the DB to your email as requested.
regards,
Alienglow
Thanks a lot! I have found and fixed a bug regarding directory names which
differ in case at the time of first sync.
Here is a link to the patched executable: (to be placed in <install dir>\bin)
[404, Invalid URL: http://ifile.it/mfq8h0s/FreeFileSync_x64.exe]
You shouldn't face issues anymore.
Additional note: The file is indeed corrupted, so a you'll see a single error
message about not being able to read the file. Ignore it and the file will be
overwritten by a fresh consistent version.
alienglow
Thanks again Zenju. Works as expected. Really appreciate your help and
support. FreeFileSync is an amazing program. Keep up the good work.
Kind regards,
Alienglow
mecki1963
Hello
I've the same problem, but besides update doesn't work on my PC. How can I
check the Internet connection settings? (Browser connection is no problem as
you can see)
Is the fix already included in the newest version? (I tried to download the
file, but it is expired)
regards
mecki
Yes, this is fixed in v3.21.
If you're talking about FFS's internal update check, then the problem is most
likely you're behind some proxy.
