Synchronization issues with OneDrive
waltermulvany
Good morning Everyone,
I have been trying to synchronize (mirror) two of my drives which are identical. The source drive has OneDrive in it, and I store all the files locally not on demand. When I try to synchronize the two drives while OneDrive is on the background (not Syncing), Freesync gives me the following error:
Error Cannot read file "E:\OneDrive\.849C9593-D756-4E56-8D6E-42412F2A707B".
The file is locked by another process:
Microsoft OneDrive [C:\Users\walter\AppData\Local\Microsoft\OneDrive\OneDrive.exe]
When I turn off OneDrive and I try to synchronize with Freesync, it gives me the following error:
Error Cannot open directory "E:\OneDriveTemp\S-1-5-21-3544562848-842807195-1815703488-1001". ERROR_ACCESS_DENIED: Access is denied. [DirReaderPlus]
It is not a big deal to do it manually, but I have been trying to make it automatic with a batch file and windows scheduler but it doesn't work since it can't mirror the OneDrive folder.
Does anybody have a solution to this issue?
Thanks for your time.
Filter it out, it is not important, just an identifier.
waltermulvany
Do you mean that the program is synchronizing and that is just a message?
Yeah, that error message is referring to a single file. I wonder is Zenju could add that to a default filter because it is the same string for everyone, it seems.
