Assume I have a sub directory tree with lots of files.
Some of them are sparse files which are (only) partially filled.
Now I want to copy this whole sub directory tree to another (NTFS) partition.
Unfortunately the sparse files are NOT copied as sparse files but blown up to their final size.
How can I tell FFS to automatically detect sparse files an to copy them as sparse files?
Other files should be "normally" copied
Peter
How to tell FFS to copy sparse files as sparse files?
If both source and target are NTFS, FFS copies as sparse by default.
By that do you mean the "Size on disk:" shows as the full file size (rather then some portion thereof)?Unfortunately the sparse files are NOT copied as sparse files but blown up to their final size.
On my end, I created a sparce.
Sync'd to another directory with FFS & the copy was copied as a sparce.
I then copied the same file using COPY (which will not preserve sparceness) & that show that the file is in fact using its full allotted size.
. And don't ask me about that 1 byte ;-)?
