I'm getting this error even if i hv verified this file is not used by any process
But FFS is reporting that this is being used
How to solve this issue?
FILE USED FAULTY ERROR
That is not what the error is saying. It's a known issue that Google Drive lets you have the same name for multiple items. You have two things named "other" so it can't sync both of them.
ahh will rename one
Can u tell me how many threads should i use for google drive?That is not what the error is saying. It's a known issue that Google Drive lets you have the same name for multiple items. You have two things named "other" so it can't sync both of them. xCSxXenon, 12 Nov 2021, 15:39
As far as I am aware, Google doesn't limit the bandwidth of you connection, and your internet speed it likely slower that what Google can handle, so threads will not help you at all.
Can u tell me how to implement Service Account for SyncingAs far as I am aware, Google doesn't limit the bandwidth of you connection, and your internet speed it likely slower that what Google can handle, so threads will not help you at all. xCSxXenon, 14 Nov 2021, 18:42
i hv 15TB total size so 750GB stops it
And about previous answer my internet speed is 100Mbps
https://cloud.google.com/iam/docs/understanding-service-accounts
Yeah, your 100 mbps connection won't benefit from multiple threads
