How to show dragged folders collapsed (and when expanded as tree view)?
pstein
Assume I drag folders (with subfolders) into the entry fields at the top and click on "Compare" button.
Then the content of all folders is automatically shown expanded.
How do I start with collapsed view? Read: the content of subfolders should initially not be shown.
Only if I click on a certain folder then its content should be expanded and shown.
Furthermore: When I click on a subfolder the content is shown rather unusual.
Files e.g. do not start indented by 2 spaces but by a vertical line far right.
How do I tell FFS to use an usual tree view like pane?
The main window doesn't support this, but in the bottom left, there is an overview with them collapsed.
Much much more discussion here:
viewtopic.php?t=7397
