File permissions are not preserved
JeremieBourque1
I am using FreeFileSync to syncronize files between two computers running Ubuntu 20.04 using SFTP. Some of these files are python files that were made executable with the command
chmod +x file.py
In the options of FreeFileSync, I have "Copy file access permissions" checked.
However, after the sync is complete, the python file is no longer an executable on the other computer. This isn't a problem if I simply copy the file via SFTP with an application such as FileZilla.
Any idea on how to fix this?
therube
States that is "requires administrator rights".
On Windows, that would imply needing to run FFS.exe "as Administrator".
On Linux, maybe it needs su -c FFS or something like that?
JeremieBourque1
I tried running FreeFileSync with sudo but I get the same problem.
The command I used is:
sudo freefilesync
I don't know if it helps but the version I have installed is 11.14
therube
Is it only .py files where this happens?
If you chmod +x a .txt file & sync that over, does that also lose the execute attribute?
JeremieBourque1
Yes it also loses the execute attribute for a .txt file.
The permission flags before synching is -rwxrwxr-x and after synching it's -rw-rw-r--
JeremieBourque1
I tried synching between two folders on one computer instead of across two computers and the permissions were preserved. So the problem only happens with SFTP.
Preserving existing file permissions is something FFS currently doesn't handle:
viewtopic.php?t=6881
