I get this description in the heading of the popup box: "Check for Program Updates"
The error code is: "Error code 0: error:00000000:lib(0)::reason(0) [SSL_read_ex] SSL_ERROR_SYSCALL"
I click Cancel and the software runs.
Error Message at Start of FFI 11.14 Donation Ed
Which operating system are you running?
The latest MacOS.Which operating system are you running? Zenju, 18 Nov 2021, 08:14
Never had a problem until now.
Is this issue reproducible with the latest FFS 11.15?
It's still showing the same error after upgrading to 11.15
Issue should be fixed now! https://www.mediafire.com/file/nsqaf8qr38rm874/FreeFileSync_11.16_beta_macOS%25282%2529.zip
