Hello all
I have purchased Macrium Reflect 8. And now I can't do a full sync because Macrium protects its backups from access. How to solve this without disabling the protection of Macrium?
With the request for support and best regards,
wisch
Macrium Reflect 8
You can't. You have to disable Image Guardian or use Robocopy.
Hello bgregory02,
too bad :-(, but thanks anyway for your support!
Have a nice Sunday and best regards,
wisch
wisch
> ... because Macrium protects its backups from access.
I don't know how Macrium protects its backups, but if it does so by means of file locking, you may try to use Volume Shadow Copy.
Make sure to read the Notes.
+1 for Volume Shadow Copy and also you can try Carbonite or Gs Richcopy360 , both have powerfull options to copy locked and opened files
I have the solution:
I will disable Macrium Image Guardian before each sync, and then re-enable it.
I can manage with that.
Another option that may work better is to have a seperate disk for those macrium backups. It also makes it easier to restore a backup if the main drive dies for any reason (I've had that happen) forcing an emergency replacement.
