How to fix error on windows 11
yak2525
i can use free file sync on windows 10 and after update windows 11 it have error below
The file "C:\ProgramData\A-Volute\A-Volute.Nahimic\Modules\Scheduled\x64\AudioDevProps2.dll" (version 2.6.7.0) is running on your system and will cause FreeFileSync to crash.
In order to avoid crashing, either uninstall "Sonic Studio 3" or update to a newer version.
You ask: How to fix error on windows 11
This is a strange question, because FreeFileSync is already telling you what to do
therube
If you want to test a Beta to see if that works for you..., viewtopic.php?t=8783&hilit=Nahimic#p31753.
