if i try to sync my linux server (SFTP) there are some files that include characters that are not allowed in windows
example
so this file cant be copied in windows , and app dont work
Sync from linux SFTP to windows filename problem
Ok, and?
viewtopic.php?t=8159
maybe an option to replace character in filename example replace : with-
> ... replace : with-
No, that is not an option.
See viewtopic.php?t=5808&p=31460#p31460.
Although that reply is about leading spaces, it applies equally well to substituting any other character in any arbitrary position.
