Using Outlook for notification
Can MS Outlook be used for sending the sync notification?
If you can write a script to tell outlook to do that, sure!
Just put the terminal-command to execute the script in the "run a command on completion" field.
Writing a script seems to be easy: https://www.google.com/search?q=powershell+send+email+outlook
Other kinds of scripts should also work somehow
Thanks for the responses. Do you need the donation version?
You only need donation for the natively supported emails, not to run a post-sync command
