I had 10 times this much and I think when I disabled the task scheduler they went away. Not sure. But back a a clean slate it's starting it again. Is this normal to keep piling these process up in Task Manager?
[/img]
Is is common to have this in Task Manager after just 2 runs?
If you are using task scheduler, it looks like they aren't completing for some reason. Are you running them as SYSTEM? Are they set to 'auto-close' in the batch_ffs settings?
I am not certain what you mean by running them as SYSTEM, I think they are being run as Administrator, yes, Task Scheduler reports Admin. I changed the batch file. Let's see if that takes. Thanks again!
You know I gotta say . . . I think changing that auto-close did it. It's been running every 30 mins for a few hours and there's no piling up of instances in Task Manager. I believe you've resolved it. I'll watch it more tomorrow but it seems fixed!! ty . . . much! jack ":-Dx
