Notification sound has quit?
jackdashack
That notification sound is not a necessity. But it was working and now it's not. When I click on the "test" play button it plays. So it knows where to find it. It's just stopped?
Does anyone have a clue what happened here?
Thanks! jack ":-\\
therube
Perhaps it's not recognizing "sync finished", even though the sync has finished?
As a test, set up a new, small sync.
Run it, & see if on its completion, you get the sound there?
On your original sync, if you add a 'Comparison finished:' sound, does that sound?
jackdashack
I will surely look at this asap. Thanks much! jack ":-Dx
therube
jackdashack
Adding a Comparison Sound seems to have done nothing.
Following the link you gave therube and changing to [ AutoClose="false" ] brought the completion sound back.
Thanks greatly. Is there anywhere for kudo's here, etc? In any case thanks for the great help!!!
jackdashack
OH, one other thing I had to change back. I had set it to run daily in Task Scheduler. It didn't like that and said 'administrator refused request' I had to change it back to 'Run One Time' as the Tutorial Video here teaches to run repeatedly, in my case every 30 minutes. All's good~
