Email sending not working while running in automatic mode
Philaupatte
I create few tasks (GUI) and associated batch files under FreeFileSync (Donation version is active for one year from today).
All is working fine when I run them manually under FreeFilesync. I receive email notifications whatsoever the case (OK, Warning, Error).
I create associated tasks under Windows 10 Scheduler (taskschd.msc). All is fine. These tasks are completed (0x0). Logs say that all is perfect, and that emails have been sent. However, I don't receive any. There are not stored as spam or whatsoever.
Have you any suggestion as I am a bit stuck. Many thanks.
If there was an error sending the email, it will be found at the end of the log file. This won't change the overall status however, which might still be "successful" regarding the actual sync. Except for the process' exit code, which will be 2 (ERROR).
Philaupatte
Hi Zenju,
No there was no error. However, I reinitiate all tasks and don't know why, all is working fine by now. I should have done something wrong for sure but don't know where. This will be another mystery in my satchel.
Many thanks
