[SOLVED] sync fails with linuxc mint upgrade
elmar
Since upgrading to 20.2 from 19.3 I cannot sync; I get the following error.
Cannot find the following folders:
/mnt/wwn-0x50014ee6aecee175-part1/Shinobi/D drive
/mnt/wwn-0x50014ee6aecee175-part1/Shinobi/E drive
/mnt/wwn-0x50014ee6aecee175-part1/Shinobi/F drive
/mnt/wwn-0x50014ee6aecee175-part1/Shinobi/Linux 2
Cannot read file attributes of "/mnt/wwn-0x50014ee6aecee175-part1".
ENOENT: No such file or directory [lstat]
Help? Machine works perfectly otherwise.
- Elmar
Did the syntax of the mounted paths change from the upgrade?
elmar
That's it - the backup drive moved from /mnt/ to /media/. Solved! Thanks.
