brew install support?
literalzebra
Was curious if support for "brew install" (previously "brew cask install") is ever planned for FreeFileSync? I recently had to reinstall all my Mac software, and FFS was one of the maybe just two or three apps I had to perform a manual install for, rather than all the rest which either automatically download from the App Store (small minority), or else I install all through a single shell script with "brew install" (vast majority, both commercial and open-source).
It seems it once worked but support was removed because it was intentionally blocked? Per:
https://github.com/Homebrew/homebrew-cask/issues/63069
Thanks, love the software as always.
literalzebra
Looking a bit more at this, I'm assuming it's because the silent install and autoupdate are part of the donation edition, and those would basically come with brew for free...
Bit of a bummer. My $0.02 would be to make silent install and autoupdate part of the regular edition (and work with brew), and instead make saved batch jobs (and maybe Google Drive too) the main two features of the donation edition... but I'm sure you've already given tons of thought as to how you structured the donation edition, and changing it going forwards introduces its own other set of headaches.
Anyways, thanks again!
marcuzzz
I just created / tested this cask, seems to work...
cask 'freefilesync' do
version '12.1'
sha256 :no_check
url "https://freefilesync.org/download/FreeFileSync_#{version}_macOS.zip"
name 'freefilesync'
homepage 'https://freefilesync.org/download.php'
auto_updates true
pkg "FreeFileSync_#{version}.pkg"
end
barry505
How can I add this to Homebrew?
marcuzzz
You can either put that in a file.rb
And run this:
brew install --debug --verbose --cask [nameoffile].rb
or you can use my repo:
brew tap marcuzzz/homebrew-marcstap
and just run brew install freefilesync
https://github.com/Marcuzzz/homebrew-marcstap/blob/master/Casks/freefilesync.rb
barry505
Thanks! You need to change the version number to 12.2 now, but thanks a lot.
marcuzzz
Done
zgypa
I'm not sure why in forums the discussion for the brew casks always point to freefilesync website, when they publish their releases on GitHub, which i would assume to be a more reliable download link.
@marcuzz: i created a PR on your repo.
https://github.com/Marcuzzz/homebrew-marcstap/pull/1
