Hello together,
I actually want to exclude the following folder from syncing. (There are also subfolders)
\#recycle\*
Since this does not work I tried to exclude files in this folder. However, this does not work either.
\#recycle\*.tar
\#recycle\*.zip
What am I doing wrong at this point?
Thanks for your help.
Greetings
Exclude folders/files does not work
If you have a hard time finding the correct Filter definitions, try running a Compare, and then right-click the file or folder to be added to the Filter, and select the correct action.
If you want, you can then open your Filter settings (the funnel icon) an see the correct Filter definition.
