Hi, I noticed that whenever I run a SYNC task, my USB drive disconnects from the computer.
But the stranger problem is that the local file path I set is not the path in the USB drive
Sync tasks can cause the USB drive to disconnect from the computer
What are you syncing to/from? Is that USB drive using a hub that is shared with one of those devices?
