free space?
sesnut
what happens when you run out of free space on the target drive?
Is it possible to mirror to 2 targets?
sesnut
by 2 targets i mean split the files if it doesnt fit into the target
Synchronzation scenarios with one source and more than one target are possible
using multiple folder pairs. However this needs to be setup manually.
sesnut
would this only be through a batch file?
how would it decide how to split the files?
FFS can't split individual files. But if you have a large hierachy of
directories, you can split these up into multiple "folder pairs" that can be
run in a single FFS session. Here it's possible to have different target
drives while source directories are from the same drive.
