Is is possible to select specific files in a directory with sub directories and sync them to a single folder on another device?
I would like to be able to select all the files with the name *200x300* from within a number of different directories and put them in one directory so when I take them to my embroidery machine I can just look at the. I can seem to find a way of doing this.
Eg
C:/stitch/Projects/
purses
1a-purse-pattern-200x300.pes
1b-purse-pattern-180x130.pes
Pockets
1a-pocket-pattern-200x300.pes
1b-pocket-pattern-180x130.pes
TO:
F:/Frames/200x300
I hope this makes sense, I'm not very computer literate.
Cheers
Jayne
flatten folder
FFS can't do this without having a pair for every folder to sync to the destination, and you'll have to change the include filter as well as use the 'update' sync method. Fairly complicated, you are probably better off just using the the built-in search in File Explorer. Search "200x300.pes" and it should find them all
I can select the files okay I just wanted to put them all in one folder instead of taking the whole directory structure with it.
Anyway, thanks for you prompt response, it has saved me a lot of time looking
Cheers
Jayne
Cheers
Jayne
