can't sync to Ubuntu network mount
apdobaj
I am attempting to sync between a local folder and a mounted network drive
using the path "smb://server/share" as reported in Nautilus, but FreeFileSync
reports "directory does not exist". What am I doing wrong?
FFS uses standard fopen/fclose/fread functions, therefore it requires regular
directories as input. Mounting a samba share locally as a folder should do.
apdobaj
I'm having some difficulties doing this using "smbmount //server/share
directory -o user=server_user,pass=server_pass,rw". error is "no ip address
specified and host not found".
mullenkamp
I have the same problem. For some crazy reason, FreeFileSync attempts to
create an intermediate folder directly after the source folder that you are
trying to sync (i.e. home\FFS 2011-07-13 085103\). The strange new folder
has FFS then the date-time. And finally, the program cannot create the folder
and fails.
Do any of the Dev know why this happens?
mullenkamp
Oh, and I do have the share mounted locally...
The reason is performance and this directory is only created if files to be
deleted are existing. After the end of the synchronization, this folder is
moved to recycle bin. You can use a different handling of deletion than
"recycle bin" to avoid this.
Just checked the sources: failing to create this temporary folder should not
lead to an error, but revert to "ordinary" recycle bin usage (even if this may
be quite slow). I've fixed this for 3.19!
mullenkamp
Thanks for the fix, I'll try it out. And sorry about the "crazy" part. I
simply use that phrase too frequently.
