Google Drive causing CURLE_OPERATION_TIMEDOUT errors
btuck
I've searched the forums on this issue and only found the one thread (viewtopic.php?t=8334) that seems to specifically relate to Google Drive causing this issue. I posted this question there but do not have a response yet. As such, I'm starting a new topic to see if anyone has ideas for this issue.
Error: Cannot read file "gdrive:\xyz@example.com\dir1\dir2\abc.zip".
CURLE_OPERATION_TIMEDOUT: Operation too slow. Less than 1 bytes/sec transferred the last 15 seconds [curl_easy_perform]
When downloading from Google Drive I get many CURLE_OPERATION_TIMEDOUT errors. They are always an exe, jar, msi, or a zip with one of those file types. All of these file types trigger a Google virus check. FFS seems to timeout before that virus check is complete. While within FFS the FTP has an option to change the timeout value, the Google Drive setup does not have this option.
I'm currently trying to use FFS to backup Google Drive content locally. Many of the files are executable and I will need to rely on FFS to download these files to have a clean backup.
Any advice is appreciated.
Windows 10
FFS Ver. 11.16 - 64bit - 1/2/2022
Added user-configurable timeout for Google Drive:
viewtopic.php?t=9116#p32916
