no sync permission for mounted nextcloud volume
stroumpf
I am using MacOS and mounted a folder from a nextcloud instance to /Volumes/username/folder. Via finder I have full read and write access to the remote folder and can copy files from and to that folder.
However, when I use FreeFileSync to sync files from my local folder /Users/name/Documents/ to the remote folder/Volumes/username/folder I get the following error:
file XXX cannot be written
EPERM: Operation not permitted [open]
Do you have any idea how to sove this?
