CURLE_RECV_ERROR: OpenSSL SSL_read: error:0A000126:SSL routines
ereyna_tritex
When I sync with Google drive, the following error occurs frequently and the sync does not work
I am using is Ver.11.6, on Windows 10
CURLE_RECV_ERROR: OpenSSL SSL_read: error:0A000126:SSL routines::unexpected eof while reading, errno 0 [curl_easy_perform]
ereyna_tritex
HEELO
Have you tried the latest version of FFS?
ereyna_tritex
Have you tried the latest version of FFS? xCSxXenon, 11 Jan 2022, 18:10
Hello, I am running the latest version V11.16
Is this an error on files transferring from or to Google Drive?
Issue with China's "Great Firewall"? https://en.wikipedia.org/wiki/Great_Firewall#Active_filtering
E.g. "TCP reset attacks"
A VPN could be used to test that
ereyna_tritex
A VPN could be used to test that xCSxXenon, 11 Jan 2022, 20:20
It looks like FFS does not automatically detect proxy software, even if it is a system proxy. The problem was solved by using proxifier.
