sync.ffs_db
FFSKnight
Thank you for developing this awesome software.
Question:
Is the a setting where I can set the size of sync.ffs_db?
Reason of my question above:
- I have a master folder that has many subfolders, some subfolders also have multiple subsubfolders.
- I use RealTimeSync to since this master folder daily.
- After about a year of daily sync, I have noticed this master folder has generated over 100 sync.ffs_db files. This has become an inconvenience as it takes longer for me to search and scroll through my files.
OR
Is there a setting to put all the sync.ffs_db files into only a specific subfolder?
e.g. MyMasterFolder/FreeFileSyncDBFolder/[all sync.ffs_db files]
Thank you.
There should only be one sync.ffs_db file per sync config, how many do you have?
