Hi, I have set my filesync to mirror between my harddrive and googledrive.
Because i have a new harddrive, i copied from my old harddrive to the new one. But freefilesync wants to copy all files again into the Google Cloud because the Date is newer now.
Do I have to wait until all is uploaded again or is there any other solution?
Mirror disk
How did you copy the data from the old drive to the new one?
Just by copy the files (drag and drop in windows explorer)
That's may be the issue, it possibly changed the metadata. You should reformat the new drive and use FFS or something else to copy from old to new.
