Freefilesync v11.16 locks
kirk.kent
After running a synchronize, the program locks up. I've tried un-installing and re-installing it and closing my AV program. Nothing works. It stops at the same spot every time. (see Attachment)
therube
OS & version?
Are all your directory pairs available, accessible?
What type of sync are you performing?
If you start a New sync, & only add, say the, D:\My Computer Programs, pair, will that successfully scan through all of those files?
kirk.kent
I tried your suggestion and traced the problem to two file types, .mds & .mdf. If either of these two file types are in any folder that I'm synchronizing, it will fail.
As a temporary fix, I've added a filter to exclude these two types.
