ERROR: CURLE_PARTIAL_FILE: server did not report OK, got 450
Tom987
Hello, I am using Free File Sync (fully updated) as FTP backup to my QNAP NAS (fully updated). Since QNAP released new update i am getting errors like this: CURLE_PARTIAL_FILE: server did not report OK, got 450. It didnt happened before QNAP Update. Sometimes backup is OK and sometimes it just dont backup like 10-20 files. If i run backup again, it will backup some more files.. I have to run backup like 10x in a row to fully backup my files.
Full eror in log sounds like this:
[12:01:27] Info: Creating File
"ftp://192.168.1.122/ZALOHA_PC/vedouci.jidelny/SIS/ZALOHA/auto20220115_1.qab"
[12:01:28] Error: Cant write file "ftp://192.168.1.122/ZALOHA_PC/vedouci.jidelny/SIS/ZALOHA/auto20220115_1~355a.ffs_tmp".
450 Transfer aborted. Link to file server lost [curl_easy_perform]
(FTP Settings are: Standard port 21 with SSL/TLS)
Do you think its FreeFileSync problem or my QNAP NAS? Thank you
jps6738
I have the same problem.
Thank you
Tom987
Did you found any solution ? Thank you
