I create command to do a mirror of folders and files.
That appear : "Code erreur 0x1128: Les données présentes dans le tampon du point d’analyse ne sont pas valides. Approximative Translate : error code 0x1128: The data present in the reparse point buffer is invalid. "
I try to find something on forum about this error but nothing.
Thank you by advance if you can help me to understand what happen
King regards
[SOLVE] Code erreur 0x1128 [ERROR_INVALID_REPARSE_DATA]
i solve the issue.
To complete my first message the error code is attached with the following : "impossible to move "D:\Documents\user\...\RecycleBin~xxfc.ffs_tmp"
in the forum i found other problem like this.
To solve, i follow this answer here https://social.technet.microsoft.com/Forums/en-US/11a0f585-b985-4a07-b6a0-f64dbce56536/onedrive-file-locked-with-quotdata-in-the-reparse-point-buffer-is-invalidquot-message :
"Open Admin command prompt:
chkdsk c: /F (i change only this without /R)
Answer Y, restart and allow disk check - this worked for me
(assumes OneDrive is on C:, if different drive then replace it with your drive letter e.g. D:...)"
And then i could delete this file.
Have a nice day
i solve the issue.
Have a nice day
