Disabling 'Completed Succesfully' dialog after mirror?
jmsmackdown
I tried searching for the forums for this and there were answers but seemingly for older versions because I could not find the settings boxes they were talking about.
What I did was create a batch file in FreFileSync and then used it to create a realtimesync. THe syncing part works perfectly but the dialog box at the end can get annoying with a bunch of changes
thank you
Open FFS, select your batch config, click 'save as batch' again, check the "Run Minimized" and "Auto-close" boxes, save.
jmsmackdown
Open FFS, select your batch config, click 'save as batch' again, check the "Run Minimized" and "Auto-close" boxes, save. xCSxXenon, 23 Jan 2022, 18:41
Ah doh! No wonder I couldn't find it. Thank you so much and sorry for the dumb question
