How to change the log directory
Fredgougou
Hi, Freefilesync is very slow on startup in my ubuntu mate.
It keeps telling me the following on startup (username is degourna)
WARNING: using XIM input method is unsupported and may result in problems with input handling and flickering. Consider unsetting GTK_IM_MODULE or setting to "ibus".
Impossible to create directory "/home/degourna".
EACCES: Permission non granted [mkdir]
Moreover I notice that in the options menu, it wants to log the files in
/home/degourna/.config/FreefileSync/logs
but I have no /home/ directory, instead it is a /home-local/ (it is a custom installation from my job and I can't do anything about it)
Is it possible to change the log directory from /home/degourna/.config/FreefileSync/logs to
/home-local/degourna/.config/FreefileSync/logs ??
thank you
frederic de gournay
therube
There are two places where log location is (can be) specified.
Tools | Options -> Default log path:
(I assume that default is simply a subdirectory to FFS's installation directory.)
After that, you can specify a different log location in:
Synchronization Settings (F8) -> Override default log path:
(I also take it that you can change the latter, but not the former [except by changing where FFS is installed].)
Fredgougou
Thank you very much, I tried to reinstall it but it fails, the message is below
The default log pah is not a subdirectory to FFS installation directory.
Thank you for the
I did not know it existed; At least I can keep the logs. Sadly it is very slow at startup (must be checking the directory)
############################################ TERMINAL OUTPUT (French, english translation below)
FreeFileSync 11.16 Setup
1. Install for all users: NO (current user only)
2. Installation directory: /home-local/degourna/FreeFileSync
3. Create desktop shortcuts: YES
Press a number [1-3] to change settings,
ENTER to begin installation:
-> Removing old installation: /opt/FreeFileSync
[sudo] Mot de passe de degourna :
-> Installing to: /home-local/degourna/FreeFileSync
-> New console command: freefilesync
mkdir: impossible de créer le répertoire «/home/degourna»: Permission non accordée
ln: impossible de créer le lien symbolique '/home/degourna/.local/bin/freefilesync': Aucun fichier ou dossier de ce type
ln: impossible de créer le lien symbolique '/home/degourna/.local/bin/FreeFileSync': Aucun fichier ou dossier de ce type
/tmp/FreeFileSync_11.16_FjKceN/install.sh: ligne 342: /home/degourna/.profile: Aucun fichier ou dossier de ce type
/tmp/FreeFileSync_11.16_FjKceN/install.sh: ligne 343: /home/degourna/.profile: Aucun fichier ou dossier de ce type
/tmp/FreeFileSync_11.16_FjKceN/install.sh: ligne 344: /home/degourna/.profile: Aucun fichier ou dossier de ce type
-> Registering file extensions: *.ffs_gui, *.ffs_batch, *.ffs_real
install: impossible de créer le fichier standard '/home/degourna/.local/share/mime/packages': Aucun fichier ou dossier de ce type
/tmp/FreeFileSync_11.16_FjKceN/install.sh: ligne 386: /home/degourna/.local/share/kservices5/ServiceMenus/FreeFileSync-edit-with.desktop: Aucun fichier ou dossier de ce type
chmod: impossible d'accéder à '/home/degourna/.local/share/kservices5/ServiceMenus/FreeFileSync-edit-with.desktop': Aucun fichier ou dossier de ce type
/tmp/FreeFileSync_11.16_FjKceN/install.sh: ligne 404: /home/degourna/.local/share/applications/FreeFileSync.desktop: Aucun fichier ou dossier de ce type
/tmp/FreeFileSync_11.16_FjKceN/install.sh: ligne 405: /home/degourna/.local/share/applications/RealTimeSync.desktop: Aucun fichier ou dossier de ce type
############################################ TERMINAL OUTPUT (personal english translation below)
[sudo] passwd fo degourna :
mkdir: can't create «/home/degourna»: not allowed
ln: can't create symbolic link '/home/degourna/.local/bin/freefilesync': No such file
ln: can't create symbolic link '/home/degourna/.local/bin/FreeFileSync': No such file
/tmp/FreeFileSync_11.16_FjKceN/install.sh: ligne 342: /home/degourna/.profile: No such file
/tmp/FreeFileSync_11.16_FjKceN/install.sh: ligne 343: /home/degourna/.profile: No such file
/tmp/FreeFileSync_11.16_FjKceN/install.sh: ligne 344: /home/degourna/.profile: No such file
mkdir:can't create «/home/degourna»:not allowed
Let's try again with the following version. The FFS installer will be using $HOME, rather than "/home/<user name>". Hopefully this works for you: https://www.mediafire.com/file/iigs5r1ro59tngh/FreeFileSync_11.17_beta_Linux.tar.gz
