Where is the GlobalSettings.xml file?
In Windows 10, when navigating to %AppData%\FreeFileSync (as per instructions in https://freefilesync.org/manual.php?topic=expert-settings), the GlobalSettings.xml file is not present. I've made sure to enable show hidden and system files in Windows but still nothing.
Thank you.
Problem: GlobalSettings.xml not present.
Oh, never mind. Apparently, upon install, you have to start and than quit the program before that file appears.
