Performance improvement
Jaguarik
Is it possible to better explain this function? I don't understand the help. Parallel file operations: E: \ next is \\ NAS \ ARCHIV and next \\ NAS \ Recycle Bin - this is versioning. I do not use an FTP server. There is a direct PC connection to the NAS via a LAN cable. I'm moving the entire "E" unit to an archive NAS. 1) what number of operations is appropriate - 2, 3, 5, 8 ....? 2) how will the number of processing and performance of operations affect if I set, for example, 8 on all units? 3) are units affected - will they slow down at the expense of the other? 4) operations processed by PC or NAS? Thank you for your understanding and response.
Parallel operations will not help here. That will only help on artificially bandwidth limited connections, usually to network locations. Transfer speeds largely depend on number of files, how many there are, and storage devices. How many files make up this 1.1TB?
viewtopic.php?t=8648
viewtopic.php?t=8674
Jaguarik
210 GB/85 000 files, large files cca 30 files - install files, videos. If I set any number, I won't mess anything up, will I?
It won't hurt anything, maybe a speed decrease
