Compare by NTFS Permission
jalal.attar
Dear Sir,
the FFS is the best way to sync folders. it is realy fantastic.
but the only missing feature is: "Compare File and Folders by NTFS Permission"
so, first option (Compare filename and size) is OK and necessary and in the most times, it is enough.
but in some situation, there is above missing feature. This feature (Compare NTFS Permission) is available in some other software such as "GoodSync" and there is checkbox options (not radio option) that allow you to select it.
in this case, supppose, you have a file that are same filename and same size. but in the Left (source), you have changed NTFS Permission. i would like to apply it (NTFS Permission) on destination too.
