I just installed FFS_11.16 on my Linux Mint 20.3 Cinnamon machine and can't create a new sync profile.
All help is appreciated.
Can't create new profile - FFS_11.16 linux
More details needed.
What are you doing?
What happens when you do it?
Any messages pop up?
Can create it but not save it?
What are you doing?
When I set everything up, I select folders that I don't want sync'd, like a mount point for my NAS and a few other folders. When I run sync, it disregards those settings and tries to sync them. I can save the profile, but it doesn't work properly, as previously described. I also get errors on the Opera Browser settings in .config in my /home/larry folder.
In the exclude filters I presume? Easiest way to filter out locations is t run a compare, then right-click the items you don't want and filter them from that context menu. Your syntax is likely the issue. There are a million error codes and messages, you can't just say "I get an error" and get any help. Be specific
